kshoulde35 Posted April 4, 2013 Report Posted April 4, 2013 Whats the powerband and peak hp difference between using small bore shearers vs. big bore shearers? Details: 300ft - 500ft drags alky 41 lectrons 4000 ft elevation Quote
Nightmare Posted April 4, 2013 Report Posted April 4, 2013 Depends on the porting. You can try asking whoever built it. Sent from my SGH-T679 using Tapatalk 2 Quote
kshoulde35 Posted April 4, 2013 Author Report Posted April 4, 2013 yea i eventually found another thread that suggested the pipes on that kind of setup were more dependent on the porting that anything else Quote
locogato11283 Posted April 4, 2013 Report Posted April 4, 2013 I really liked BB on my 10mm Cub. I never ran SB so I can't compare. Windy swears up and down that SB are better for a 10 Cub. Quote
banshee760 Posted April 4, 2013 Report Posted April 4, 2013 Sb ftw , that's what they were made for Matt himself will tell you that , also on the smaller motors the pipe is made for revving wich in turn that's where the cubs make most of the power Quote
locogato11283 Posted April 4, 2013 Report Posted April 4, 2013 Sb ftw , that's what they were made for Matt himself will tell you that , also on the smaller motors the pipe is made for revving wich in turn that's where the cubs make most of the power Just because Mat says a specific pipe was built for a specific motor doesn't necessarily mean it's going to the best pipe in every single set up. I'm sure he would never in a million years recommend his BB in-frame for an 18DM when it actually makes within 6HP of his out-frames for that motor. Just saying. Carry on. Quote
Crazykane Posted April 4, 2013 Report Posted April 4, 2013 There is a member on here that dyno BB & sb shearer on 10mill cub the same dyno same day. Sb made 6 maybe 8 less. I'm assuming every motor could be different Quote
special06shee Posted April 4, 2013 Report Posted April 4, 2013 i have a 10cub built by redline. im running shearer sb's. the bike works super great with them, power everywhere. cameron told me that bb's would probably make a couple peak hp up top but would probably give up some of the bottom and mid range. Quote
kshoulde35 Posted April 4, 2013 Author Report Posted April 4, 2013 Im getting the idea it's going to be very motor specific as far as pipes to match the port work... Quote
locogato11283 Posted April 4, 2013 Report Posted April 4, 2013 i have a 10cub built by redline. im running shearer sb's. the bike works super great with them, power everywhere. cameron told me that bb's would probably make a couple peak hp up top but would probably give up some of the bottom and mid range. Cam built my 10mm Cub also. I had OG Rockets on it to begin with. Bought a set of BB Shearers and ran them. I don't think I even talked to him about it. I just did it. Quote
special06shee Posted April 4, 2013 Report Posted April 4, 2013 If i was competing in timed comps. or truly raced against others im sure i would of tried a set of the bb's for sure! But for what i do with my shit turd i kinda was after a broad curve so i am totally cool with giving up some hp on the big end. Quote
possum Posted April 5, 2013 Report Posted April 5, 2013 Just because Mat says a specific pipe was built for a specific motor doesn't necessarily mean it's going to the best pipe in every single set up. I'm sure he would never in a million years recommend his BB in-frame for an 18DM when it actually makes within 6HP of his out-frames for that motor. Just saying. Carry on. my thoughts as well. Quote
possum Posted April 5, 2013 Report Posted April 5, 2013 im considering trying bb inframes on my 10cub. sb inframes now. i wonder??? Quote
locogato11283 Posted April 5, 2013 Report Posted April 5, 2013 Now that I am home and not typing from my phone, I will expand on my previous post. What I mean in saying that a certain pipe may not work best for every single motor of a certain type, 10mm Cub in this example, is that not everyone uses the motor the same way. Typically, Shearer or any other pipe builder is trying to sell you that their pipe makes the most peak horsepower. In some uses, peak horsepower may not be the best way to go or best for that build. Maybe you need a broad curve or more bottom end opposed to peak horsepower. Set up is key. Pipe choice should be decided on when you understand what you're going to be doing with the motor and how the pipe will affect that. Quote
