4mil is 4 mil. 110 or 115 rod. It's the pin that's moved on the webs. A 110 can use standard banshee pistons. A 115 uses 795, with these the wrist pin is moved 5mm higher. Dropping the piston down. Same amount of stroke which ever you chose.
