Ak_grizzly
Everything posted by Ak_grizzly
  1. Great condition surefire m600 with red lens,pod switch,grip, and Quick disconnect $150 + ride Thanks %5BIMG%5Dhttp://i1002.photobucket.com/albums/af148/rudog_01/DSC08790_zpsf7a5177c.jpg
  2. pair of Elka stage 4 triple rate shocks set up for a 180lbs xc rider $700 shipped Thanks %5BIMG%5Dhttp://i1002.photobucket.com/albums/af148/rudog_01/DSC08782_zps03aebd72.jpg %5BIMG%5Dhttp://i1002.photobucket.com/albums/af148/rudog_01/DSC08781_zpse4c3db9b.jpg %5BIMG%5Dhttp://i1002.photobucket.com/albums/af148/rudog_01/DSC08780_zps928111d2.jpg
  3. Pro design shifter PM
  4. Ok....i'll try that Thanks BUILDER
  5. I hope this Helps %5BIMG%5Dhttp://i1002.photobucket.com/albums/af148/rudog_01/DSC_8748_zps5e2311e8.jpg %5BIMG%5Dhttp://i1002.photobucket.com/albums/af148/rudog_01/DSC_8747_zps109d0caa.jpg %5BIMG%5Dhttp://i1002.photobucket.com/albums/af148/rudog_01/DSC_8746_zps52f0b118.jpg %5BIMG%5Dhttp://i1002.photobucket.com/albums/af148/rudog_01/DSC_8745_zps81513385.jpg
  6. %5BIMG%5Dhttp://i1002.photobucket.com/albums/af148/rudog_01/DSC_8743_zps31a65a4b.jpg
  7. I forgot....the air mixture screw,set at 1 turn and the niddle is at second grove from the top.
  8. I let you know tomorrow how the plugs looks likes
  9. How can u tell if airstrikers or regular pwk,,,,,
  10. I have a 4mil sand ported motor with FMF gold series pipes, K&N pods, Coolhead with 22cc domes, vforce 3 reeds with 36mm Kehim Carbs and +4 on the timing plate. My problem is in first gear it bogs from no throttle all the way to 1/2 throttle then it pulls good to redline from 1/2 to Full throttle. I pulled the carbs and found the Pilot Jet was 50 and the Main jets were 150. I bought the carbs on Banshehq and I am not sure if these are the right size jets for my setup. Any recommendations? I filled out the Jetting FAQ below. 1) What type of aftermarket exhaust do you have?....... FMF gold series 2) What type of airfilter do you have?....K & N Pod 3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all..No airbox 4) What is your elevation? (If you don't know, go here: http://www.topozone.com )....120 feet 5) What size pilot jets are you using?....50 6) What size main jets are you using?....150 7) What temperature is your Banshee jetted for?....don't know 8) Do you have a port job? yes...by custom sandz 9) What kind of carbs?..... Keihim 10) What size carbs?....36mm
  11. For Sale Hella Rallye 4000Xi $350 shipped %5BIMG%5Dhttp://i1002.photobucket.com/albums/af148/rudog_01/th_DSC08654_zps349b04a7.jpg %5BIMG%5Dhttp://i1002.photobucket.com/albums/af148/rudog_01/th_DSC08655_zps1dbc1b75.jpg
  12. what sprocket to use
  13. What brand Thanks
  14. Here's my cooling fan wiring. %5BIMG%5Dhttp://i1002.photobucket.com/albums/af148/rudog_01/th_Fan_zps619d4caa.jpg
  15. Here some video %5BIMG%5Dhttp://i1002.photobucket.com/albums/af148/rudog_01/th_IMAG0002_zps6b07c0a3.jpg %5BIMG%5Dhttp://i1002.photobucket.com/albums/af148/rudog_01/th_IMAG0046_zps0b6831fc.jpg
  16. Are they good reg/rec though,anybody had any problem using this product. Thanks
  17. Looking for regulator/rectifier 1 phase 12 volts 200amps Pls...let me know Thanks
  18. Ak_grizzly
    WTB Intake
    Looking for billet intake for 38mm Let me know Thaks
  19. Both Thanks
