I have a 4mil sand ported motor with FMF gold series pipes, K&N pods, Coolhead with 22cc domes, vforce 3 reeds with 36mm Kehim Carbs and +4 on the timing plate. My problem is in first gear it bogs from no throttle all the way to 1/2 throttle then it pulls good to redline from 1/2 to Full throttle. I pulled the carbs and found the Pilot Jet was 50 and the Main jets were 150. I bought the carbs on Banshehq and I am not sure if these are the right size jets for my setup. Any recommendations? I filled out the Jetting FAQ below.
1) What type of aftermarket exhaust do you have?....... FMF gold series
2) What type of airfilter do you have?....K & N Pod
3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at all..No airbox
4) What is your elevation? (If you don't know, go here: http://www.topozone.com )....120 feet
5) What size pilot jets are you using?....50
6) What size main jets are you using?....150
7) What temperature is your Banshee jetted for?....don't know
8) Do you have a port job? yes...by custom sandz
9) What kind of carbs?..... Keihim
10) What size carbs?....36mm
