outlander1000 Posted March 23, 2013 Report Posted March 23, 2013 I have not decided on what size carbs I want to get for my new build. I plan to do 90% trail riding so I was thinking maybe 33mm? Also I need to get a set of pump gas domes... emailed a few sponsors but never heard back from them. Anywhere have them that I can just buy online without emailing or calling? Quote
Nightmare Posted March 23, 2013 Report Posted March 23, 2013 You can probably get away with 28's. Sent from my SGH-T679 using Tapatalk 2 Quote
trickedcarbine Posted March 23, 2013 Report Posted March 23, 2013 The 33's will let it breathe more then enough flow yet keep some response in the tight stuff. You could be ok wih 28's, but I think with a motor that size you will be wanting more and the 33's will be a perfect medium. Quote
outlander1000 Posted March 24, 2013 Author Report Posted March 24, 2013 The 33mm it is. What are my filter/box options? I have the K/N with adapter plate now in a box and would like to still run a box but no pods. I like the idea of the aluminum airbox but not sure what boots it would use to the box? Still need to get some domes for this motor. Got almost all the other parts. Quote
outlander1000 Posted March 24, 2013 Author Report Posted March 24, 2013 Would love to do a single carb setup but I think I would be disappointed if it is anything like a 2-1 exhaust. Quote
camatv Posted March 24, 2013 Report Posted March 24, 2013 use the stock box or a custom alluminum one. the domes try FAST or NOSS for a setup. if some shop is building the motor for you they should already have a dome setup and carb setup to recomend. Quote
outlander1000 Posted March 24, 2013 Author Report Posted March 24, 2013 I emailed both FAST and NOSS... I never have time to call anywhere at work or forgot I'm so busy. I'm building the motor myself. The stock airbox boots are not large enough for the 33mm carbs are they? Quote
trickedcarbine Posted March 24, 2013 Report Posted March 24, 2013 Noss for domes Pods if it doesn't get to wet. If it does, modify the stock box with different boots, and some trimming to get it in and out easier. Quote
