my banshee
(1999) will not rev. it idles but rough after i cut thee green and yellow wire coming from the cdi. it idles low and like tings and if i puch the gas it bogs. i know it is electrical not fuel problem. when i hook the green wire back up and twist the wires to the parking brake switch it gains a thousand  rpm but does the same thing.the throttle switch is cut also HELPPPPPPPPPPP!!! my kill switch is fine and key switch is bypassed. thanks in advance. im stumped  banghead motor is grounded. i guess i just need to know what wires to twist, cut or disable
Not sure but, if you want to get rid of the tors for it to work properly youll need to buy the T.O.R.S eliminator kit, if you hook up all wires that you cut it should run fine, Best guess is hook up green and yellow wires back up. Maybe TPS is fried? Not sure sorry man
