Ok I have a 2003 shee and I drove it into a deep puddle. It started to miss after that. I have cleaned all plugs and got it to run rite. It has started to do it agen and I have a buddy that's big on shee's and he has been helping me out. We are both stumped at this point. It's only running on the left cylinder we have cleaned the carbs 2 times and even put a different set of carbs on it does the same thing. Cleaned them also. We have pulled the wiring out of the quad and ohm'ed every connection to each one and it all looks good. I have taken the coil in and it checked out good. Even took my buddy's off of his running shee and still the same thing. Cdi out of his running shee and same problem. Swapped plug wires and stays in the right side. I ohm'ed the stator and it all checks out good. Even pulled the stator out of my buddy's and tryed it and the same problem. Even with his fly wheel and same problem. It has 105 pounds of compression in both cylinders. We are both mechanically inclined. Carbs are in sync. We have taken the motor out and are rebuilding it rite now. But I was thinking the piston was cracked. But it looks good. I'm scared that I'm going to rebuild this motor and its going to do the same thing. The only thing I can think of is crank seal or the crank has twisted. Am I crazy? Can anyone help me?
i found snorting coke when rebuilding the motor is very helpful turns a 6 hour job into a 6 minute job.
Did you pull the plugs and crank the motor over 1000x's to get the water out? I'm not being rude it's an honest question, had to do it on my sled, FYI don't bother using the same plugs, get new ones.
You pulled the top end apart??
Then you ohmed out the harness??
Ohm out the coil, cdi, etc. My money is on one of them or a spark plug boot or something simple. Confirm that there is no spark on one side THEN proceed.
Thier is spark on both plug wires. I ohm'd everything and its all within spec. And I have pulled top end off all looks good. Taking the crank in to get checked out. The only funny thing I have seen is that the domes on the head are clean like almost new looking and the top of the pistons have carbon build up on them.
Thats a bad ass puddle to take out a crank.
Why are you shooting from the hip? You said its not running on the right cylinder. It either has no spark, no fuel or no compression on right side.
I know what your saying. But it has 105 pounds in that cylinder; has spark on both cylinders, and has fuel. Has everything it take to run. But the right side don't run. The only thing I can think of is the the crank on the right side has moved off of timing. Im not just shooting from the hip. I tryed everything I could before I tore it down like this. Read a forum that said piston could be cracked or washed out the rings. But it all looks good. I have built a lot of different motors and have never seen anything like this before.
