camatv Posted March 6, 2014 Report Share Posted March 6, 2014 21's/ Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted March 6, 2014 Report Share Posted March 6, 2014 No street racers run pump fuel or your at a dissadvantage already , I have seen more exotic shit done with fuel on backroads then at the track, do u have any other mods done the head is not gonna give u the edge like other mods , porting, tranny, pipes, carbs , whats your compression at now Quote Link to comment Share on other sites More sharing options...
gordo Posted March 13, 2014 Report Share Posted March 13, 2014 im running 19cc on stock crank and ported cylinders and i do dunes, drag and everything in between..i run 91 and never had an issue..big weekends i do a 50/50 mix of race fuel and 91. Quote Link to comment Share on other sites More sharing options...
WINDYCITYJOHN400 Posted March 15, 2014 Report Share Posted March 15, 2014 im running 19cc on stock crank and ported cylinders and i do dunes, drag and everything in between..i run 91 and never had an issue..big weekends i do a 50/50 mix of race fuel and 91.Why race fuel mix on "Big Weekends"? Quote Link to comment Share on other sites More sharing options...
gordo Posted March 15, 2014 Report Share Posted March 15, 2014 it seems i pull a bit harder up the hill running a bit higher octane Quote Link to comment Share on other sites More sharing options...
WINDYCITYJOHN400 Posted March 15, 2014 Report Share Posted March 15, 2014 it seems i pull a bit harder up the hill running a bit higher octane If you can FEEL the difference….then your motor needs it ALL the time. Especially if you hot lap the bike. 1 Quote Link to comment Share on other sites More sharing options...
gordo Posted March 16, 2014 Report Share Posted March 16, 2014 91 octane does the job..ill get up on banshees with oof pipes running 91...at almost $90 a container for an hour ride, it doesnt make sense..I never fouled a plug, seized an engine and my set up has out lasted many banshees..easily run 2 maybe 3 seasons on same top end..at end of 3rd season ill just redo the engine(maybe itll last another season but piece of mind outweighs risk) Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted March 22, 2014 Report Share Posted March 22, 2014 im running 19cc on stock crank and ported cylinders and i do dunes, drag and everything in between..i run 91 and never had an issue..big weekends i do a 50/50 mix of race fuel and 91. Your logic is flawed. I lost a lot of cylinder life and a top end when my engine detonated like their was no tomorrow. I had 19 domes in my 4mil running 93 pump gas. It needed higher octane. Also dont understand mixing more octane on "big weekends". Then in post #23, saying 91 octane pump gas does fine without any issues. My guess is it wouldnt be burning as efficient with higher octane fuel therefor hurting performance. Quote Link to comment Share on other sites More sharing options...
gordo Posted March 22, 2014 Report Share Posted March 22, 2014 I would say trial and error..my bike is an all purpose bike and I get on it in the dunes(uphill drags, straight drags,) 91 octane runs does the job. I have never seized an engine or dropped a cylinder due to octane. 19 cc dome and my bike is 91 friendly Sent from my SCH-I545 using Tapatalk Quote Link to comment Share on other sites More sharing options...
RadarRacing Posted March 22, 2014 Report Share Posted March 22, 2014 Not getting into an arguement about dome size and octane but rider weight , pipe design and how well the pipe works with your particular port design , how lean and tuned you run your bike , timing , dome design ,even base gasket thickness are all variables that can make a motor detonate or NOT detonate. Off the shelf pro design domes are pretty mild in design. If you get domes from a builder that designs them to higher squish velocity or with a 1/2-1mm wider squish band then they will be much more prone to detonation even if the CC is the same. Quote Link to comment Share on other sites More sharing options...
gonzodesign Posted April 8, 2014 Report Share Posted April 8, 2014 Radar Racing, not many can argue with you as your making alot of sense, all 19cc domes are not alike as you said, once the exhaust port is raised now things are very different, I have 15 19cc domes from 4mm wide squish to 12mm they all require different set ups but I see time and time again people say I'm going racing and run race gas and are actually slowing down their vehicle. Quote Link to comment Share on other sites More sharing options...
