I want to get an idea where should I start with my main and pilot jets. My set up will be:
- keihin pwk 28mm carbs
-V force 4 reeds
-toomey t5's
-It has wisco pistons and a slight bore but I don't think that matters
-stock stroke
-stock head
I'm at about sea level to 200ft and I want to jet for around 60 degrees ambient temperature.
Any help would be great. Would 160 main be a good start? Thanks
Im not sure of what pilot. Ill have to check. So am I right in saying as the numbers go up it gets richer and as the numbers go down it get leaner? I guess ill start with the 160 and work down.
  • 1 month later...
ok so i went with 158 main 45 pilot and JJH needle on middle clip.
when wot it don't bog, but it doesn't sound smooth. it hesitates kinda
and also sometime when taking off from a stop while on a hill it bogs down if i don't give it a lot of throttle.
Any suggestions?  :D
also i used 1/4 inch fuel line and it is still too big (leaking), what did you guys use?
play with the needle clip up and down and see if that fixes it. my guess is that it need to be leaned out in the midrange.
I would imagine you will end up somewhere closer to 148-150 depending on what filters your running.
I had pods with FMFs running a 148 jet and my brothers with pro circuits was 150 main with pods. Both stock stoke/head and around 700' elevation.
im running stock air box with lid, no snorkel, and a uni air filter. When I find the time I will lean out the main jet to see what happens and post back with results.
  • 3 weeks later...
I run a bored .040 over, stock stroke, trail ported motor, airbox no lid w/ Proflow plate and K&N(sometimes pod filters), Pro Design Coolhead - 22cc domes, Keihin 28PWK's and Toomey T5's
....and im usually healthily close at 158-160 mains and 48 pilots, with whatever the stock needle is.
I tried the 150's and it ran much much better, but not perfect. It still sputtered WOT. Tried the 148 and it now runs awesome. I'm planning on getting the bike up to temp, put new plugs in, then run it WOT in 6th and shut it off to see if what the plug looks like. I'm going to be pretty disappointed if they are not brown.  :flush:
