Pastrykiller Posted February 11, 2013 Report Posted February 11, 2013 Ok gents...I don't recall seeing this in the search. For those who own pwk's and want to do a full rebuild and also like to soak your carbs. When you buy a rebuild kit, it excludes a certain gasket. This gasket is between the jet block and body of the carb. If you like to use brake cleaner and/or soak your carb, this gasket will swell and shrink and possibly create a permanent rich condition. Here is the part number Jet Block Gasket Part #1202-834-2000 Can be found at sudco and is usually on back order. Get em while they got em for 4.25 a piece. Look like Here where it goes There are two tamper proof torx screws that keep the jet block secured. You will need a special torx bit to remove it. Use a little grease on the gasket to keep it adhered to the jet block during install. Quote
trickedcarbine Posted February 11, 2013 Report Posted February 11, 2013 Huh, good to know. Thanks my good man. Quote
Pastrykiller Posted February 11, 2013 Author Report Posted February 11, 2013 What size torx is it? T-? That's a really good question. I didn't have the tool so I turned the bolt head into a flathead with a file. I replaced them with a pan head Phillips bolt and the threads are 4mm x .70 Quote
rjdgriff Posted February 11, 2013 Report Posted February 11, 2013 What size torx is it? T-? That's a really good question. I didn't have the tool so I turned the bolt head into a flathead with a file. I replaced them with a pan head Phillips bolt and the threads are 4mm x .70 Haha nice Quote
