lms1977 Posted February 9, 2013 Report Posted February 9, 2013 Yep I had a stock banshee with fmf pipes I put 27.5 pilots and 260 mains in it and it ran good. Quote
joewest Posted February 9, 2013 Author Report Posted February 9, 2013 Thanks guys. Ill check the jets today and clean the carbs. Ill look into the TORS some more too. Quote
sleeper06 Posted February 9, 2013 Report Posted February 9, 2013 New York sea level,30 pilot, 280 mains,stock needles all the way rich,snappy as shit on the throttle Quote
sprinklerman Posted February 9, 2013 Report Posted February 9, 2013 Thanks guys. Ill check the jets today and clean the carbs. Ill look into the TORS some more too. If you decide to go with the Pro Flow kit with K&N filter,let me know,i have a used one in good shape for sale ,thatll save you a few bucks. Quote
trickedcarbine Posted February 9, 2013 Report Posted February 9, 2013 That pretty much covers it. The only thing I didn't hear touched on was the clutch. There is a drastic difference between your banshee and that 4 stroke you compared it to. Especially if the guy before you said he put a HD replacement in. You can help it by getting a fresh cable and routing it with out any major bends and keep it lubed. Also get your self a nice perch and lever. Steer clear of the junk magnum one.something like an ASV or Wertz would help drastically. Maybe go back to a lighter spring since your bike probably doesn't really need the heavy springs. The last option that would be costly but if you are serious about a really easy pull. Get a lock up so you can run the lightest springs possible but not have clutch slip. A bit over kill, but I think if I build another trail bike it'll definitely get one just so I can put really soft springs in it. Quote
joewest Posted February 9, 2013 Author Report Posted February 9, 2013 Ok thanks guys. Is the pro flow kit really worth the money? Quote
WaynokaBanshee Posted February 9, 2013 Report Posted February 9, 2013 Ok thanks guys. Is the pro flow kit really worth the money?yes bot pods are better. Quote
sprinklerman Posted February 9, 2013 Report Posted February 9, 2013 yes bot pods are better. Not true. The OP said he rode trails and it was a "bolt-on" style bike with stock carbs. Pods add nothing to that situation but more exposure to water. The Pro Flow will make the same HP and protect against water/puddles better. Quote
joewest Posted February 11, 2013 Author Report Posted February 11, 2013 U think it needs to be rebuilt? Quote
Burt Reynolds Posted February 11, 2013 Report Posted February 11, 2013 Banshee? no low end? normal Quote
