There will be a lot of different answers on this.  I prefer stock heads...milled and rechambered for my needs & for two reasons...it's cheaper and I like the stock look.
Well cool head gives you the option of changing domes. Just buy a new set and install them and keep it moving. as far as which has more power i'm not sure. If you want a sleeper motor then go with stock milled, if not then I would run cool head. JMO.
Just milling a stock head is only doing 1 thing.  Increasing compression..  To do it right, it needs to be re chambered.   That being said. A cool head (after market head) and stock head are the same.  But.. There is limitations with the stock head.  Some profiles are not possible with a stock head and this is where some builders prefer cool heads.
