turbowrenchhead Posted February 6, 2013 Report Posted February 6, 2013 Who has new zerks? I have two that won't take grease on the shock support. Quote
BeeCanBanshee Posted February 7, 2013 Report Posted February 7, 2013 Hardware store. Lowe's, home depot etc. Quote
Starwriter Posted February 7, 2013 Report Posted February 7, 2013 It might not be the zerk. It could be the hole in the pin is gunked up. Quote
turbowrenchhead Posted February 7, 2013 Author Report Posted February 7, 2013 Hardware store eah, I've never seen them at ACE but then again I wasn't looking. Quote
Nightmare Posted February 7, 2013 Report Posted February 7, 2013 NAPA Sent from my SGH-T679 using Tapatalk 2 Quote
Nightmare Posted February 7, 2013 Report Posted February 7, 2013 Yes Sent from my SGH-T679 using Tapatalk 2 Quote
turbowrenchhead Posted February 7, 2013 Author Report Posted February 7, 2013 Know what size off hand or does it matter? Quote
Nightmare Posted February 7, 2013 Report Posted February 7, 2013 8mm I believe. My bikes are a couple miles away and can't really check at the moment:lol: Sent from my SGH-T679 using Tapatalk 2 Quote
WaynokaBanshee Posted February 8, 2013 Report Posted February 8, 2013 Orileys is where I get mine And 8mm is the size. Quote
Pastrykiller Posted February 8, 2013 Report Posted February 8, 2013 Ace hardware has them. Remove the zerks and clean them out. My link wouldn't take grease until I took a small pick and removed the grease from the underside that had turned rock hard. Quote
turbowrenchhead Posted February 8, 2013 Author Report Posted February 8, 2013 I got new zerks from my auto parts supplier Quote
turbowrenchhead Posted February 8, 2013 Author Report Posted February 8, 2013 I put the zerks in and it still won't take grease on two of them. I'll have to pull the hardware and clean it out. Quote
Starwriter Posted February 8, 2013 Report Posted February 8, 2013 Duh, what'd I tell you? Maybe you should have stuck the possibly plugged zerk in the grease gun by itself and checked to see if it flowed grease. Or swapped 1 of the working zerks into the bad hole. Quote
