I plan to just start buying parts so when I see a fare deal I want to grab parts I will need for a future build.
What is recomended to hop up my motor for trail and some times the dunes.
Right now I only have a stock motor K&N filters and pro circut pipes.
I Plan to get good shocks  / new A arms  and if suggested a + 4 swing arm
 I picked up a billet intake, I plan to get V force 4 reeds and bigger carbs ( what size carbs should I watch for ? )
Plus when it comes to the main motor  what would I want ?
depends on the route you plan to take.  If your going to go with a port job from a site sponsor then your going to need to get a lower size dome to increase your compression as your intake durations will be longer meaning you'll have less compression.  Id say go with a cool head, some 28 pwk carbs, +4 timing, reeds, and get your crank welded and send your cylinders out for a port job. Will seriously wake up your bike.
