sykotic_banshee Posted January 26, 2013 Report Posted January 26, 2013 Want to buy a plus 6 swingarm but don't have a lot of $ to spend any help on a good one to get Quote
joshb Posted January 26, 2013 Report Posted January 26, 2013 Probably a used one on here that retains a stock carrier setup. Quote
Finch Posted January 26, 2013 Report Posted January 26, 2013 Probably a used one on here that retains a stock carrier setup. why would ya wanna keep the stock junk carrier? but x2 a used one on here is your best bet Quote
joshb Posted January 26, 2013 Report Posted January 26, 2013 You wouldn't but from what I have seen the ones that retain the stock stuff are CHEAP. Quote
joshb Posted January 26, 2013 Report Posted January 26, 2013 Just suggesting probably his cheapest alternative. There is a +4 round house that has 35 mm bearing in the parts section that would be good . Only if a +4 would work though. I would get that over one that uses stock stuff. Quote
locogato11283 Posted January 26, 2013 Report Posted January 26, 2013 I would save up your money and buy round house. You can get carriers for close to $100.. Quote
theneil Posted January 26, 2013 Report Posted January 26, 2013 what are the advantages of a roundhouse? it isnt like an lt250 quadracer style is it? ive only had bad luck with those Quote
joshb Posted January 26, 2013 Report Posted January 26, 2013 No. Like 250r style I think they call it. They look a whole lot better for one. Very easy to adjust also Quote
joshb Posted January 26, 2013 Report Posted January 26, 2013 http://bansheehq.com/forums/index.php?showtopic=163043#entry1434557 Quote
joshb Posted January 26, 2013 Report Posted January 26, 2013 http://bansheehq.com/forums/index.php?showtopic=162634#entry1430106 Quote
joshb Posted January 26, 2013 Report Posted January 26, 2013 As opposed to something like this http://bansheehq.com/forums/index.php?showtopic=162690#entry1430700 Quote
joshb Posted January 26, 2013 Report Posted January 26, 2013 Hope you don't mind all these links http://bansheehq.com/forums/index.php?showtopic=162702#entry1430845 Quote
