jamesnug Posted January 25, 2013 Report Posted January 25, 2013 Have a banshee bored out to 420cc and on Tommy t5 pipes, went to it the evening and unfortunantly put suspension oil in the mix with petrol, ran it for about 30 mins and then died out, took it back up to the house and drained it once i realized the wrong oil was in and put in the proper stuff. after this the quad would not kick start, got it going after kicking for about 2 hours, anyway now the problem seems to be the right side down pipe is not heating up in sync with the left, also there appears to be a much reduced pressure coming out. the quad has lost power. any advice is much appreciated asap. Quote
Sandking Posted January 25, 2013 Report Posted January 25, 2013 Do a compression check you may need to do the top end. Quote
jamesnug Posted January 25, 2013 Author Report Posted January 25, 2013 any other ideas on what it could be, hopefully not as bad as that?lol Quote
ric-ross1 Posted January 25, 2013 Report Posted January 25, 2013 Drain the suspension/gas out and get right oil and gas ratio change plugs and see. But a compression test is a great idea. Quote
jamesnug Posted January 25, 2013 Author Report Posted January 25, 2013 i dont think it the plugs because she is staring up after couple of kicks and exhust still not heating up atal but other 1 is goin 100% and not near as much pressure out of the other pipe but other 1 working fine Quote
sheerider11 Posted January 25, 2013 Report Posted January 25, 2013 I'm sure you toasted that top end Quote
jamesnug Posted January 25, 2013 Author Report Posted January 25, 2013 fuck that would be hateful is it dear to fix Quote
ric-ross1 Posted January 25, 2013 Report Posted January 25, 2013 ^ thats what i was going to say but wanted to give him that other option besides the comppression test. Quote
jamesnug Posted January 25, 2013 Author Report Posted January 25, 2013 so yas think she is fucked ;/ Quote
Paul M Posted January 26, 2013 Report Posted January 26, 2013 99% chance ! Do a compression test ! If its bad do a bore job and new pistons no biggie ! . crank should ok maybe .. Quote
sheerider11 Posted January 26, 2013 Report Posted January 26, 2013 99% chance ! Do a compression test ! If its bad do a bore job and new pistons no biggie ! . crank should ok maybe .. doubt it. I don't know the properties of shock oil, but I'm going to assume the worst and say it 100% breaks down in gasoline. So you had zero lubrication. Like I said I'm stating the worst scenario. But to score up the cylinder to lose all compression, I'm sure you had some serious heat. So I would pull the crank to check the bearings Quote
troyzstang Posted January 26, 2013 Report Posted January 26, 2013 Welcome to BansheeHQ. Sounds like you've learned a valuable lesson. Read the label Check compression as already suggested. Good luck. Troy Quote
04_blu_shee Posted January 26, 2013 Report Posted January 26, 2013 Sad to hear of your delima but im with sheerider11...it might be a spendy repair Quote
jamesnug Posted January 26, 2013 Author Report Posted January 26, 2013 thanks every 1 for your comments it was soo stupid of me to do it ;/ i am getting a man to look at her to day and see what have i done ;/ Quote
