This was cake. Get ahold of a plumbers chain wrench that will fit the diameter of the flywheel.Unscrew the pickup coil and stuff it inside and out of the way. Using your chainwrench make sure you have it on the outside of the flywheel to avoid the risk of warping.After you have locked it tight rest the wrench portion on the footpeg. Now turn the flywheel nut and youre set! Any questions let me know.
