Should there be play up and down on the needle .. About 1/8th inch .. I am switching to a set of airstrykers and while I had them apart and switched the needle out I noticed play up and down that the regular pwk don't have .. Some one had a little pieces of red rubber between the needle and where the cable hooks to take up the play is that suppose to be in there ?
Sounds like something is a little worn out. Try a new c-clip and see if it fixes it. Maybe a new slide and nut after that. There shouldnt be any play.
Jared
I figured this out..thought I would share for any one else that might have this .. Some one has drilled out my slide to drop the needle down and lean it out .. Along with this they put small washers on the main jet to drop them down as well ..
