Just installed tors eliminator kit. Kicked it over an started up for about 2 secs at very low idle and shut off. Will not start back up. Does it have anything to do with the new screw turns? I messed with them and still not startin. Any suggestions??
you probably need to grind down the "nubs" where you tapped for the idle screw some more..or screw the screws in more, maybe both.
