bustedknuckles Posted December 29, 2012 Report Posted December 29, 2012 Ok I bought the Athena 68mm kit about a month ago, I haven't had a chance to put the motor together yet. I was wondering what I would have to do to in order to get a 4mm crank to work with that set up. Quote
trickedcarbine Posted December 29, 2012 Report Posted December 29, 2012 Depends, did you buy it for stock stroke? Quote
bustedknuckles Posted December 29, 2012 Author Report Posted December 29, 2012 Stroke says 54mm so yes Quote
oldskool Posted December 30, 2012 Report Posted December 30, 2012 You would have to port your cylinders for a 58mm stroke,shave head unless you have a cool head, then you just need domes cut for +4mil crank. Then your piston choice will depend on whether you go with long rod(115MM) or short rod(110mm) Quote
