banshee kick starter
Tilt it on its side. (just prop the clutch side of the bike about 18", don't drain the fluid). Pull the coolant lines and plug them (coolant loss should be minimal). Pull the cover off and check it out. The engagement is very simple and you should quickly be able to tell what is or isn't going on with the kicker assembly.
SP
