middle crank seal?
banlee
There is no seperation in pressure inside the crankcase, this is different than compresion. Compresion is only in the topend not the crankcase.banghead
yes i understand that. i was just thinking there need to be pressure to force air into the cylinder. but the more i think about it the piston creates a vacuum effect to pull it in. i understand now.
wrong.... because.....vvv
In between the center crank bearings there is a Labyrinth seal.
a labyrinth seal uses oil as the seal to separate right and left. it's sitting there in between the 2 bearings. there should be sealant, or an o-ring on it, to seal against the case, iirc....
