tristan Posted October 15, 2012 Report Share Posted October 15, 2012 Fuel flow from pet cock but when i hook lines to carbs no fuel just air in lines Quote Link to comment Share on other sites More sharing options...
Josh Z Posted October 15, 2012 Report Share Posted October 15, 2012 Fuel flow from pet cock but when i hook lines to carbs no fuel just air in lines Probably a plugged needle jet.... take your carbs all the way apart and clean them. Quote Link to comment Share on other sites More sharing options...
old put-put Posted October 15, 2012 Report Share Posted October 15, 2012 check your carb vents, check your fuel inlet on carbs for blockages. How much fuel is in the tank, is fuel filter clogged etc? Quote Link to comment Share on other sites More sharing options...
tristan Posted October 15, 2012 Author Report Share Posted October 15, 2012 Tank is full banshee just got all put back together and cleaned Quote Link to comment Share on other sites More sharing options...
old put-put Posted October 15, 2012 Report Share Posted October 15, 2012 Tank is full banshee just got all put back together and cleaned are your float needles stuck shut? floats move freely? Quote Link to comment Share on other sites More sharing options...
tristan Posted October 16, 2012 Author Report Share Posted October 16, 2012 Not sure bc when i mess with fuel lines and tap carb it runs fine Quote Link to comment Share on other sites More sharing options...
old put-put Posted October 16, 2012 Report Share Posted October 16, 2012 Not sure bc when i mess with fuel lines and tap carb it runs fine then there is your answer, good luck, floats and needles it is. Quote Link to comment Share on other sites More sharing options...
banshee4mil Posted October 16, 2012 Report Share Posted October 16, 2012 check the fuel tank vent, make sure it will flow right with the cap on and off, also try blowing through the fuel lines to the carb/s if its still stock carbies then tap on the carbs to free up the floats maybe that will let them drop if there stuck Quote Link to comment Share on other sites More sharing options...
tristan Posted October 16, 2012 Author Report Share Posted October 16, 2012 Fuel flows freely with or with out gas cap and have tried it when lines hooked to carbs and nothing Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted October 16, 2012 Report Share Posted October 16, 2012 X2 on the floats and needles. The needles and seat get crap built up on them and won't open to let fuel in the bowl. Quote Link to comment Share on other sites More sharing options...
