Hey guys I'm in the process of rebuilding my motor and I wanna get ride of the boost bottle I have 28m carbs with pro design intake now qustion is
Can I use some 1211 gasket maker and just plug them and get rid of boost bottle?
This is what i did Chance, with the PD intakes.
Cut a automotive fuel line to length (I cant remeber I.D size off hand). Hucked a Gates Unicoil on ($5) so it didn't kink and BAM clamped it on. Or plug them with hose and a bolt per side and clamps.
It was going to be a quick fix when i did it, but it has held up fine for a few years so i left it be.
Too the dummies above, the PD intakes take a different style bottle, the stock x-over wont work.
I can check on the size if you need it...
A hardware store like true value should have rubber plugs. Think the kind that goes on top of the beakers in science class.
2 of them and 2 hose clamps would be a quick easy fix.
I use them to plug my exhaust before a wash.
Savage I heard if you lengthen that hose by about 6ft and route all around your frame it gives you a super boost bottle effect- about 5hp per foot :)
Well i tried 5ft at first, and didn't notice much gain, so i down sized :ph34r:
