topfli8979 Posted September 18, 2012 Report Posted September 18, 2012 Hello, Just bought my first banshee. Had lots of 250'rs and raptor 660/700. But this is the first big 350 stroker. It built 17mill domes,hotrod crank,cpi inframes,stock bore, 35mm kehin slide frame alchohol carbs. My problem is there is no where local to buy alky fuel, and I just wanna go back to pump gas. Can I use the same carbs and just rejet? Or do I scrap them for a whole new setup. Quote
vulvafan537240 Posted September 18, 2012 Report Posted September 18, 2012 You can convert mikunis back to gas but not keihins. What kind do you have? Quote
topfli8979 Posted September 18, 2012 Author Report Posted September 18, 2012 You can convert mikunis back to gas but not keihins. What kind do you have? I was mistaken these are mikuni slide frame 35mm, I have keihin on my 250r. SO it can be changed back? Quote
Finch Posted September 18, 2012 Report Posted September 18, 2012 mikunis can be id contact a builder and see what all ya need to do or sell them and buy some gas carbs Quote
#1JUANstunna Posted September 18, 2012 Report Posted September 18, 2012 I was mistaken these are mikuni slide frame 35mm, I have keihin on my 250r. SO it can be changed back? Replace the dumps in these carbs, get the right needles, and change pilots and mains. Then you should be back to gas carbs. Quote
topfli8979 Posted September 18, 2012 Author Report Posted September 18, 2012 Replace the dumps in these carbs, get the right needles, and change pilots and mains. Then you should be back to gas carbs. Okay great, now for a dumb question where should I start on the sizing? Quote
#1JUANstunna Posted September 18, 2012 Report Posted September 18, 2012 Okay great, now for a dumb question where should I start on the sizing? Just order the stock needle jets from pj motorsports http://www.pjmotorsports.com/ Email Sarah with the type of carbs and what you need and she'll take care of you. Quote
topfli8979 Posted September 18, 2012 Author Report Posted September 18, 2012 Just order the stock needle jets from pj motorsports http://www.pjmotorsports.com/ Email Sarah with the type of carbs and what you need and she'll take care of you. Okay will do thanks fo the help. I beleive my carbs are TMZ does tht sound right for a mikuni slide carb. Quote
#1JUANstunna Posted September 18, 2012 Report Posted September 18, 2012 (edited) Okay will do thanks fo the help. I beleive my carbs are TMZ does tht sound right for a mikuni slide carb. TM or TMX Edited September 18, 2012 by yamahaman126 Quote
topfli8979 Posted September 18, 2012 Author Report Posted September 18, 2012 TM or TMZ Maybe TMX, I dont know it says no where on the carb. Quote
mike0chek Posted September 20, 2012 Report Posted September 20, 2012 might as well get a handful pf all the jets and you will have them. Quote
topfli8979 Posted September 25, 2012 Author Report Posted September 25, 2012 might as well get a handful pf all the jets and you will have them. Okay, tried contactin pjmotorsports have not had anyone contact me back. Still stuck on what to do, guy at the bike shop is clueless, said since he didnt know what the carbs were originally mounted he could not help with getting it back to stock gas carbs. I need some help, I going to the dunes at the end of the month if I can get it back together. Quote
Finch Posted September 25, 2012 Report Posted September 25, 2012 I'd hit up wikdcard hes pretty good with mikunis Sent from my SGH-T999 using Tapatalk 2 Quote
