topfli8979
    2003 Banshee, 17mill domes,hotrod crank,stock bore,cpi inframes
topfli8979's Achievements
  1. Banshee is on ebay if anyone is interested. Just enter into search item #111008884017.
  2. I wondered about that also, just passing the only info I have along.
  3. I have never had it on a dyno, prior owner said he put it on the dyno right after he installed the cpi pipes. Right around 90HP.
  4. Sorry should have added, this bike is setup for alcohol, I have been trying to rejet the carbs back to pump gas. Other came up, I need it sold.
  5. 2003 Yamaha Banshee Stock bore, trinity port polish Boisen reeds mod quad cool head 17cc domes mikuni 35mm tm slide carbs, KN filters Brand new rear dwt rims CPI INFRAMES with silencers. $2,500 In Springfield,Missouri
  6. Okay, tried contactin pjmotorsports have not had anyone contact me back. Still stuck on what to do, guy at the bike shop is clueless, said since he didnt know what the carbs were originally mounted he could not help with getting it back to stock gas carbs. I need some help, I going to the dunes at the end of the month if I can get it back together.
  7. Maybe TMX, I dont know it says no where on the carb.
  8. Okay will do thanks fo the help. I beleive my carbs are TMZ does tht sound right for a mikuni slide carb.
  9. Okay great, now for a dumb question where should I start on the sizing?
  10. I was mistaken these are mikuni slide frame 35mm, I have keihin on my 250r. SO it can be changed back?
  11. Hello, Just bought my first banshee. Had lots of 250'rs and raptor 660/700. But this is the first big 350 stroker. It built 17mill domes,hotrod crank,cpi inframes,stock bore, 35mm kehin slide frame alchohol carbs. My problem is there is no where local to buy alky fuel, and I just wanna go back to pump gas. Can I use the same carbs and just rejet? Or do I scrap them for a whole new setup.
