SLOPOKE21 Posted September 18, 2012 Report Posted September 18, 2012 I am wondering if its worth the extra money to go to a supercub. I know it involves case work and what not, but I keep reading about the supercubs not being able to breathe right with the small reeds. Is this true, and can I run the supercub with small bore oof shearers? Any info is appreciated. Quote
WINDYCITYJOHN400 Posted September 18, 2012 Report Posted September 18, 2012 I am wondering if its worth the extra money to go to a supercub. I know it involves case work and what not, but I keep reading about the supercubs not being able to breathe right with the small reeds. Is this true, and can I run the supercub with small bore oof shearers? Any info is appreciated. Pistons are quite a bit more money. Super cub in a 7 mill with require BB pipes. Some will say you could get away with running the SB's, but I think you would be leaving potential HP on the table. I had the Full Cheetah with the 72 bore (Same piston as the super cub) I just went to a 10 mill cub and am very happy with the results. The 4-7-10 mill cubs are real runners. Quote
locogato11283 Posted September 18, 2012 Report Posted September 18, 2012 No point in building a 7mm anything unless you're racing in a specific CC class. Build the 10 and be done with it. Quote
SLOPOKE21 Posted September 18, 2012 Author Report Posted September 18, 2012 Yeah I understand that about the 7mm, but I traded my broken 4mil setup and some cash for this setup. That's why I have a 7mil. I am starting on another motor and it will be a 10mil something, not sure on cylinders yet. I am just gonna go with the cub now I believe. I want something that's very reliable and don't have to worry about tearing into it all the time. It sounds like that's what will happen with the supercub. Quote
