OK if anybody read my post a few weeks back I switched to 110 and my bike slowed down. After all kinds of work and headache meds here is what I've got...........
Kevin cut me some domes (tried 19cc and 20cc) My compression was up around 190. He said based on everything he wanted to do some different porting (had his Hardcore MX 4 mil port) so I send the cylinders back to him. He opened the exhaust up some more and did a little work on the intake. Put it back together and it runs just like it did on pump gas with 23 cc domes. (remember is was slower on 110 before the new port work)
My thinking is I'm justing making all the power I can get on my setup. Right or Wrong? Would it be worth my time to take my T5's off and try a set of CPI's? Any other ideas?
Mods are in my sig
My jetting is right on IMO 155 main 42 pilot and on the 2nd clip
squish was .042
ran the timing at +6 +4 and 0 didn't make a difference
tried 110 from 3 places mixed a little 93 in once and ran some 100LL It runs its best on the 110
I'm running the stock gearing with 20 tires I did try a 15 tooth front just for the hell of it......might run a little better from a 2nd and 3rd gear roll but not enough to make up for what it would lose off the line vs the 14 t
I swapped my old old Rad valves out for a set of VForce 4's
Flywheel is good
BTW sidenote Kevin (HJR) has broken his neck helping me. Calls me back after hours, he loaned me a set of the domes to see which worked better, did my new port work the next day after he got it, exc. Needless to say I'm going to send him a Christmas gift. I've not talked to him since I did my test and tune tonight to get his thoughts. Saving that til Monday. LOL
i got his dune port on a 4 mil and when i switched pipes from fmfs to shearers i liked how the bike performed better.any kind of drag pipe would of been better then what i was running with my port. it had more top end powerband pull which is what i wanted so it depends on what you want the bike to do. if i had the $ to do another build right now i would of def gone 10mil or higher and went with a different cylinder. i love my ported 4 mil stock cylinder dont get me wrong but the addiction takes over and i want more power :headbang: did you try a lower compression for shits and giggles to see how it performed? ( higher cc dome) im kind of surprised though that when you went with higher compression and race gas that it slowed down. maybe too much pressure working against the crank with the port job? idk kinda talking out my ass here after a long night im :shootself: . someone else can chime in on here. im sure you would like a different pipe though. its not gonna be as crazy of a difference as like when you got it ported but a different pipe will give it a different feel. kev will get you the best answer but just my 2 cents.
Edited by bluebanshee98
I think your jetting sounds lean. What is your elevation? Which carbs exactly?
Just run the 110 straight. Don't mix it.
Leave the timing at +4.
Pipes are definitely holding you back. You're probably down 5-8 HP from what you'd be with CPI, Sniper, Shearer or Rockets.
Keihin 34mm Pj's is all Ive ever know these carbs by?
Our elevation is around 1500 feet
& yes that is why it was slower before simple terms (that all I understand) it couldn't get all the exhaust out
Gonna borrow a set of CPI's this week and try them out
34PJ are a very temperamental carb.
The jetting has to be spot on in them or the motor won't run right.
I think you'd benefit from running some 35PWK which are much more forgiving.
Don’t sell it. It will make so much more power with Shearer or CPI's with some 35PWK's you won’t believe it.
bike feels like it runs better in 4th gear plus than it does in 1-3??
May trade it on a 350 Warrior w electric start LOL
