i have a 1987 banshee its bored .30 over it has answer equalizer silencers(never heard of them before). it was stock airbox and stock carbs. the jetting i have right now is a 200 main and a 25 pilot.
it is hard to start when cold and has a very high idle
any help is appreciated
id try it might ba a lil rich not sure sure with stock pipes and carbs . id try it and if it doesn't bog or foul plugs id run with it. and to your other thread if tors is removed there should be a idle screw that goes into the slide out for lower idle in for higher idle the a/f screw is back of the carb where the boot hooks them to the box
