Hey all,
I have been sent here by the guys from thumpertalk
they say here is the place to get all my question answered.
I have a 05 Banshee project going on.
So here is my first question which and probably a common one.
I am going to have the frame powder coated,
But the stem bearing doesn't want to come out
and I am wondering since its not a high speed bearing
if we mask it off would it survive the 500+ degree oven??
thanks
Did you unscrew the large retaining nut under the seal?
If you don't have the tool take a 3/4 nut (bolt size) and use 1-1/8 socket to pull the retainer out then the bearing will come out the top side easily.
Take the bearing and seals out and replace them. It's only $15 for the bearing and both seals. They do go bad. And if you don't want to look like an idiot, cut the unused brackets off the frame. Here's the tool I use to remove the bearing retainer. Some people take a bolt and jamb 2 nuts together on the bolt and then use a wrench or socket.
Pry upper and lower seals out with screwdriver. Use your tool of choice to unscrew bearing retainer out counterclockwise. Pound bearing upwards from the bottom.
What size Bolt is that?
