So today I took my banshee for a spin, everything was ok till I got back home. When I went to shut it off it didnt want to turn off by the OFF/Run Switch nor did it want to turn off by the Key. (The switch for the lights was working fine) Any ideas? Thank you
  • Replies 45
  • Created
  • Last Reply
Top Posters In This Topic
Dude just take a look. If everything is handed to you, you'll never know how to really fix anything. So if this or anything happens riding you'll have an idea of what to look for.
Get a clymers. You'll use it more then you think
Pull both spark plug wire simultaneously..thatll. Shut the bike off for,sure :cheers: :cheers: :cheers:
Edited by bebetekbanshee358
You give me your car ill show you. Lol. Nah take off your tank plastic. If your sitting on the quad it will be on your left hand side between your Rad and your tank. You guys can just tell.someone black and white wire happy hunting. That's not nice.
First off I do mechanic work on power stroke so I'm not a noob at all on wrenching. I don't see anything here be handed to me. Thanks for your concern though.
Alright cool I will take a look thanks
Ok I will take a look, have you ever heard of this before?
Yea. I had my key switch tucked away behind the tank. Took the key out on off didn't matter. Ripped that out, wired in a tether and never had a problem.
Found the wire, it was connected. Anymore suggestions?
what i did to figure this out on a 3 wheeler before is take that black/white wire while its running and touch the bare end of the wire to the frame. it should die if not that wire has a break in it somewhere. if it does then you switch is faulty.
best advice is take all that stock crap off your bars. get a push button cr style kill switch or tether to replace the on/off switch.then wire a 3 way targa switch somewhere hidden that controls your lights. i put my targa where the tors was as there allreay alil mount ...... works like a breeze and uncrowded handle bars look so much better imo . look down at my bars /pics below .goodluck
Edited by shakar
I will try that next. (Reminder: its happening on both switches: Key switch and OFF/Run switch)
