Whats going on if you have your plugs showing two colors at the tip. 2/3 of the plug is black and the rest is light chocolate color. BTW my oil mix is kinda rich, 20:1 I think.
Unless you are on alky you need to fix the 20-1 , run whatever oil you want at 32 or 40-1 and jet your bike correctly and stick to a that ratio. Im not being a smart alek but the reason it has unburned sticky oil on the electrode is pretty simple. Not enough heat to burn all the oil. Is your jetting off??? I dont know.
