muddripper14 Posted August 28, 2012 Report Posted August 28, 2012 would an air leak cause my banshee to not start unless its bump started or if i spray starting fluid in the carbs. Quote
Finch Posted August 28, 2012 Report Posted August 28, 2012 check comp thats the only time ive ever had to pull start one is low compression or weak spark Quote
muddripper14 Posted August 28, 2012 Author Report Posted August 28, 2012 i did check the compression and its 120 in each cylinder Quote
ATVridinMaNiAc Posted August 28, 2012 Report Posted August 28, 2012 Check spark, ohms the stator, sometimes a weak spark causes the bike to not start by kick start but it will when skid started because it spins the engine over faster creating a stronger spark, just something to look into. Quote
Jereme6655 Posted August 28, 2012 Report Posted August 28, 2012 Also check that the crossover tube between the stock carbs is in place...... Quote
mike0chek Posted August 28, 2012 Report Posted August 28, 2012 are you getting any backfire sounds?? Quote
muddripper14 Posted August 31, 2012 Author Report Posted August 31, 2012 ya i do get a little bit of back fire Quote
WINDYCITYJOHN400 Posted August 31, 2012 Report Posted August 31, 2012 #1 guess......flywheels moved on the crank. #2 guess......bad batch of gas. #3 Electrical issue #4 cams are worn out. Quote
muddripper14 Posted August 31, 2012 Author Report Posted August 31, 2012 inside the boots on my coil was pretty rusty could this be the problem Quote
