350skabarat Posted August 14, 2012 Report Posted August 14, 2012 Does not look like it? Take the caps off and measure it all up? See if its even possible for the slide to move all the way up. Quote
dajogejr Posted August 14, 2012 Report Posted August 14, 2012 No sir, they are not. Either: A. The thumb throttle does not swing far enough to open all the way. Common on bigger carbs and using the stock thumb throttle on a banshee. Many people grind the stocker so it has more throw/room. B. The cable it wrong/too long C. The spring is binding it up not allowing it. IF this has a screw off type top (can't tell 100% by the picture) loosen the top 1/8 turn. I've had stock banshee carbs bind when I overtightened them, loosening the cap just a hair fixed it no problem. You are definately not getting wide open by those pics, though. Let us know what the problem is. My guess is A or B. Quote
guns4children Posted August 14, 2012 Author Report Posted August 14, 2012 I think its the stop in the stock throttle. Quote
NYUK Posted August 14, 2012 Report Posted August 14, 2012 grind the stop off!. how long u had this set up? Quote
dajogejr Posted August 14, 2012 Report Posted August 14, 2012 Guns, there's an easy way to see if that's the problem. Take the cap off the stock throttle. Remove the cable, pull the cable by hand and look through the back of the carb. If it opens all the way, it's not the cable or the slide binding up, it's the throttle. Quote
guns4children Posted August 14, 2012 Author Report Posted August 14, 2012 grind the stop off!. how long u had this set up? I got this set up when I built the serval. Quote
#1JUANstunna Posted August 14, 2012 Report Posted August 14, 2012 I got this set up when I built the serval. Maybe this explains your "huge" HP numbers on the dyno. lol Quote
sheerider11 Posted August 14, 2012 Report Posted August 14, 2012 You got a lot of dirt in your carbs it looks like Quote
guns4children Posted August 14, 2012 Author Report Posted August 14, 2012 You got a lot of dirt in your carbs it looks like Just a bit of k&n oil Quote
lms1977 Posted August 14, 2012 Report Posted August 14, 2012 no full throttle for guns his mom made him set it up like that if you need a hand bring it down one day Quote
possum Posted August 14, 2012 Report Posted August 14, 2012 It can also be that ur top cap adjusters arent long enough. Quote
guns4children Posted August 15, 2012 Author Report Posted August 15, 2012 Ok fucked with it and got it this far. I can pull on the top of the Carb and its as far up as it will go. I guess now I have to fuck with the insides. Can someone post pics of their 35pwks wide open? Quote
guns4children Posted August 15, 2012 Author Report Posted August 15, 2012 I also have the extended Carb tops and easy springs from FAST Quote
