  • Replies 52
  • Created
  • Last Reply
Top Posters In This Topic
No sir, they are not.
Either:
A. The thumb throttle does not swing far enough to open all the way. Common on bigger carbs and using the stock thumb throttle on a banshee. Many people grind the stocker so it has more throw/room.
B. The cable it wrong/too long
C. The spring is binding it up not allowing it.
IF this has a screw off type top (can't tell 100% by the picture) loosen the top 1/8 turn. I've had stock banshee carbs bind when I overtightened them, loosening the cap just a hair fixed it no problem.
You are definately not getting wide open by those pics, though. Let us know what the problem is. My guess is A or B.
Guns, there's an easy way to see if that's the problem.
Take the cap off the stock throttle. Remove the cable, pull the cable by hand and look through the back of the carb. If it opens all the way, it's not the cable or the slide binding up, it's the throttle.
