sootman73 Posted August 3, 2012 Report Posted August 3, 2012 The other day i rode a well built banshee that made alot more power than mine and it shifted way smoother than my quad. He had a lockup clutch and short clutch lever and it was still easier to pull and to shift than my quad. What mods do I need to do to my quad to get it shifting easily? I drag race alot and missing shifts is not an option anymore. I plan on doing the shift star mod and adjusting the clutch. possibly replacing the clutch cable but i don't think it needs that. (clutch is new FAST racing light duty) Quote
BigRed350x Posted August 3, 2012 Report Posted August 3, 2012 If all you do is drag race, then go get yourself an override. If you do other riding mixed with drag racing, then do the following: side-cut your gears shift star mod shift pro kit (but keep the heavier stock spring, don't use the shift-pro spring) shift shaft mod 2nd bearing on the shift drum Try that and see how you like it. -Jared Quote
WINDYCITYJOHN400 Posted August 4, 2012 Report Posted August 4, 2012 And buy a new clutch cable. Quote
BigRed350x Posted August 4, 2012 Report Posted August 4, 2012 And buy a new clutch cable. I agree. Since you would have to split your cases to get the gears side-cut, you might as well replace the clutch actuator arm bearing that's pressed into the cases, get the new clutch cable Windy suggested, and get yourself a nice clutch lever like an ASV. -Jared Quote
sootman73 Posted August 4, 2012 Author Report Posted August 4, 2012 Thanks for your help. Whats involved in cutting gears? I've heard of this but haven't looked up what exactly this is. Quote
mike0chek Posted August 5, 2012 Report Posted August 5, 2012 Thanks for your help. Whats involved in cutting gears? I've heard of this but haven't looked up what exactly this is. there are a few guys on here that have a good rep for cutting gears, i believe one is named "camatv" Quote
thomas h. Posted August 5, 2012 Report Posted August 5, 2012 I just had mine done by Herr jugs racing and they work good. Quote
thomas h. Posted August 5, 2012 Report Posted August 5, 2012 I just had mine done by Herr jugs racing and they work good. He did the shift star and Yakkey shift drum( my request ) as well. Quote
sootman73 Posted August 7, 2012 Author Report Posted August 7, 2012 I searched for the shift shaft mod but couldn't get a clear understanding of it. Is there a write-up to explain it? Jared can i source the Shift-Pro kit through you? PM me a price if you stock them. Quote
BrockMoto Posted August 7, 2012 Report Posted August 7, 2012 If all you do is drag race, then go get yourself an override. If you do other riding mixed with drag racing, then do the following: side-cut your gears shift star mod shift pro kit (but keep the heavier stock spring, don't use the shift-pro spring) shift shaft mod 2nd bearing on the shift drum Try that and see how you like it. -Jared Everything in this list, ^ he can do for you Quote
thomas h. Posted August 7, 2012 Report Posted August 7, 2012 I searched for the shift shaft mod but couldn't get a clear understanding of it. Is there a write-up to explain it? Jared can i source the Shift-Pro kit through you? PM me a price if you stock them. I think it has a lighter spring. I think that it doesnt help and is not recommend. But maybe ask around. Quote
BigRed350x Posted August 8, 2012 Report Posted August 8, 2012 I searched for the shift shaft mod but couldn't get a clear understanding of it. Is there a write-up to explain it? Jared can i source the Shift-Pro kit through you? PM me a price if you stock them. Hey man, I'm just an average joe rider like most on here. I would say give Kevin @ HJR a call, he can hook you up with the shift pro kit. You can also get it from cascadeinnovations.net Quote
sootman73 Posted August 8, 2012 Author Report Posted August 8, 2012 Hey man, I'm just an average joe rider like most on here. I would say give Kevin @ HJR a call, he can hook you up with the shift pro kit. You can also get it from cascadeinnovations.net Gotcha thanks for your help Jared. Quote
sootman73 Posted October 27, 2012 Author Report Posted October 27, 2012 Wow finally got my shift mods installed and took it for a test drive! holy shit this thing is fun to ride again! and neutral clicks in so easy that on the stand i don't even have to pull the clutch in! Thanks guys for your help and damn i wish i woulda done this a long time ago! Quote
Zbadboy Posted October 27, 2012 Report Posted October 27, 2012 Just curious what all mods you installed? Did you do all that where suggested or just some? Quote
