when i start my banshee and rev on it alittle it has a whining sound .sounds like clutch side when u ride it on decell u can really hear it .i changed the clutch looked around in there didnt c anything out of ordinary. this is my third banshee and never seen this one does any one have had this problem and what is it?
toe honest it would probably be best at that point to split the cases and remove all the bearings and replace them all.....if one is at he end of its life who knows about the rest. or you coudl just remove them one at a time and spin them on your finger......you'll know when you find a bad bearing....
I could be way off, but when I think of turbo noise I'm thinkin' air flow. As in air leak. I have saw a Polaris that had a whine that came from an intake boot. Give that thing a pressure test as well
its def a bearing sound the more i hear it its just got me wondering which because it makes noise in neutral but more in gear on decell im thinking bearing behind clutch basket ? was hoping someone else has had same expeiriance to pin point the problem
