sheeNZ Posted June 15, 2012 Report Posted June 15, 2012 hey guys have noticed a slight knocking noise coming from my trans. the bike rides algood shifts algood idles algood when clutch is in or owt. just wandering if its normal? or something is wrong.. any info on what it could be would be much appreciated.. Quote
shakar Posted June 15, 2012 Report Posted June 15, 2012 you sure it coming from the trans?? if its knocking it could and prob is trouble......... goodluck Quote
bansheesandrider Posted June 15, 2012 Report Posted June 15, 2012 (edited) If it is coming from the clutch cover area, you could have had the clip come off the kick idler gear and run through the primary drive roughing up some gear teeth and make them knock. Just my 2 cents. Edited June 15, 2012 by bansheesandrider Quote
Tedder Posted June 15, 2012 Report Posted June 15, 2012 Thats not normal. Better dig into it now and find the cause. The cost of repairs will just keep going up if you continue running it. Quote
SheeManWomenHater Posted June 15, 2012 Report Posted June 15, 2012 Have you ever heard of a motor that "knocks" and its 100% normal? I haven't.. everything should be smooth. Quote
drap660 Posted June 15, 2012 Report Posted June 15, 2012 Could be clutch basket bushings..... Take a look before it gets worse Quote
2strokespirit Posted June 16, 2012 Report Posted June 16, 2012 Could be a grooved clutch basket... Pull the clutch while the bike idles for a few seconds and listen if you still hear the noise.... Quote
possum Posted June 16, 2012 Report Posted June 16, 2012 Could be clutch basket bushings..... Take a look before it gets worse This Quote
