72mm supercub on 4mm stroker crank need a good 1/8th gear ratio using hoosier D10 slicks
how are those tires? do they hook up good on the street ? and are they the ones with the box pattern treads ??
X2, but need more info! Tire diameter, primary ratio, transmission & bike/rider weight.
yes the tires are box thread pattern they break at first but hook pretty good on the road im about 175 in wieght the bike has a 1-5 overide trans and i bought the tires off some one they where new all thats on the is hoosier D10-10-10 and also has straight cut 2.68 gear ratio 4mm stroker crank long rods 72mm cheetah super cub full drag porting with +8 swingarm fireball keyed 34mm axle
You could try the 17 up front , keep the 38 rear. You can put a 37 on it. if u buy the honda rear sprocket setup you can get smaller sprockets on the rear. i no of people runing rear sprockets as small as 33. A lot of our 1/8th mile bikes with similar set ups are eithr 16-38 or 37 or 17-38 or 37. do us really well and have been in the 5s. its trial and error but we dont use that tire. we use american racers and they hook exceptionaly well on the street. just buy a couple different sprockets and make some passes at the track. good luck
