Having problems on take off when drag racing! I have a 14mm cheetah and when I take off it starts off good for about 30 feet then it bogs down before powerband kicks in! If anyone could help me with this I would really appreciate it. Thanks
too much tire/ gearing?
How much weight do you have on your lockup / what springs are you using on your primary? What tires / gearing? What gear are you launching in? Have you tried adding a little air pressure to the tires? Go up a tooth or two in the rear sprocket.
We just spent 10 days at Little Sahara and the bike was running great then all of a sudden it started bogging. If I keep it full throttle it would come out of bogging and take off like a bat out of hell! Bike has Cheetah with 10mil stroker and runs in 120s for horsepower, 2-5 override with 1st gear removed, straight cut gears with billet 2nd gear. Not sure what went wrong but I would really appreciate some feedback. Thanks for all the help
could b a number of things bud carb issue with pilot jets clip come off needle flywheel key stator come lose and move process of elimimation bud
