coryv4 Posted May 22, 2012 Report Posted May 22, 2012 well as many of you know i am running a turbo 421. i was riding ita nd it ran fine built 10lbs of boost no problem i came back idle to launch again and it drapped a cylinder and would boost over 6lbs and it was fluttering inbetween 3 and 6lbs. i pulled it in to the garage and check comp both cyls are at 115lbs has spark carbs are clean but my coolant is kinda oily. im am lean twards a bad oring but im not building preassure in my radiator. Quote
Starwriter Posted May 22, 2012 Report Posted May 22, 2012 Don't turbo motors go through reeds like a hooker goes through condoms? Quote
mopar1rules Posted May 22, 2012 Report Posted May 22, 2012 While I was a memeber of another forum, I read about a fellow that turboed a Banshee and if I recall correctly, it would beatup the reeds right away. Quote
sheerider11 Posted May 22, 2012 Report Posted May 22, 2012 I can't understand how it just doesn't float the reeds and make them useless. Quote
coryv4 Posted May 22, 2012 Author Report Posted May 22, 2012 found out the problem upon further inspection i broke the gay ass small pedal off the boyseen dual stage reeds. is there a better reed that may handle the flow a little better? im not running as high of boost as most other guys are. Quote
n2otoofast4u Posted May 23, 2012 Report Posted May 23, 2012 A- TDR .020 turbo reeds B- STOCK The other reeds are too brittle. Quote
MyNameIsMud Posted May 24, 2012 Report Posted May 24, 2012 This sounds like a neat build any pics of it? Quote
