03DMshee Posted May 22, 2012 Report Posted May 22, 2012 going to clean up cooling system and delete bottle...please let me know if i have this right..thanks delete bottle including feed and return lines cap and clamp vent line under water pump cover case vent hose out to atmospheric rad hoses stay where they belong nipple off fill on rad to atmospheric if theres anything im missing or any precautionary measures i need to take please let me know thanks Quote
03DMshee Posted May 22, 2012 Author Report Posted May 22, 2012 thanks for the quick response! another question is can i use CLR safely in these rads? Quote
03DMshee Posted May 22, 2012 Author Report Posted May 22, 2012 yeah...i run it through heatercores all the time but wasnt sure if there was anything differant with these rads Quote
My03banshee Posted May 25, 2012 Report Posted May 25, 2012 yeah...i run it through heatercores all the time but wasnt sure if there was anything differant with these rads curious about using the CLR too? Could it be bad for the seals or rubber parts or anything? Quote
DirtDiggler69 Posted May 29, 2012 Report Posted May 29, 2012 I'm putting my top end back together in the next few weeks , and I was assuming I would just use a 50/50 mix of antifreeze/ water , but what does everyone else run? I ride the dunes and obviously it's a work-out on the motor . Does anyone ride dunes here and just runs water only? Or use a water wetter product in the water? Quote
2strokeshees Posted May 31, 2012 Report Posted May 31, 2012 No reason to run CLR... If you want a good flush, drain the system, fill with water, run it for a few minutes, drain again, then take a blow gun and blow threw the radiator cap and push all the water off. All I use my banshees for is dune riding and I will honestly swear by Engine Ice. They claim to run alot cooler and I swear my bikes run cooler. Look into that and buy some, 1 jug fills our radiators. Cheap and a good product IMO. Quote
Chip M Posted May 31, 2012 Report Posted May 31, 2012 I'm putting my top end back together in the next few weeks , and I was assuming I would just use a 50/50 mix of antifreeze/ water , but what does everyone else run? I ride the dunes and obviously it's a work-out on the motor . Does anyone ride dunes here and just runs water only? Or use a water wetter product in the water? Engine Ice straight, no mix. Rules!! Quote
