Jereme6655 Posted May 15, 2012 Report Posted May 15, 2012 Hey guys....needing some help here. I've had a low end bog ever since Ive gotten the bike..... It runs HARD up top and pulls perfectly fine in the mid. But when it comes to trying to take off....shit...that's a diffent story. He to either rev it and slowly slip off the clutch (I mean SLOWLY) or it bogs hard and you almost have to pump the throttle to get it to come back. Elevation is 700 01 shee FAST dune/play port .10 over FMF fatties 2-1 foam filter VF 2's Pro design w/ 20cc domes Jetting is at 330 and running a 30 pilot ....stock needle middle clip. The bog has been with the bike ever since I picked I up......however it was horrible t first.....and the guy had the pipes and filter on it with stock jetting....but I'm getting frustrated here. Any help would be appreciated guys.... Quote
BelleauCarl Posted May 15, 2012 Report Posted May 15, 2012 You should have 27.5 pilot and play the air screw a little to fine tune Quote
Larry's Shee Posted May 15, 2012 Report Posted May 15, 2012 X2 ^^^ What are your air screws at now? Quote
wacko2000 Posted May 15, 2012 Report Posted May 15, 2012 I'd say your def rich on the pilot, try bringing your air screws out to 2 1/2 turns If that helps, your def rich on the pilot and a 27.5 should clear it all up Joe Quote
Jereme6655 Posted May 16, 2012 Author Report Posted May 16, 2012 Alright ill drop in the 27.5's i got. The air screws are currently at 1.75 out I believe. Thing is I swear it was bogging even with the 27.5's in it.....egh well.....time to keep wrenching. Quote
