Where can I buy a set of uni pods with outerwears?
Rockymountainatv.com has them. Why on earth would you want one of those crappy filters? Get a K&N and some outerwears...
Will they be alright for trails? I'm mostly gonna ride in sand but may do a little trail riding and possibly some ice racing in the winter.
Edited by emtbanshee
k&n's are junk in my opinion!! i have had no luck with them what so ever!! my carb slides were alway dirty with k&N filters!! and yes i cleaned and oiled them properly. i just switched to uni filters!!
12 years, K&N pods the whole time on 3 different machines. 2 total top ends and it was just to freshen things up. And trust me I ride in some of the dustiest shit around and puddles. Just put some outerwears and clean the filters often. It's easy.
X2 :headbang: K&N FTW!
My slides are clean every time I inspect them. I even put a dab of white lithium grease on the inside edge of the filters to see if anything makes it into the filter. The grease always looks good as new. :shrugani:
I just bought a uni-pod and it is a real K&N with a outer wear. It looks like it needs to be mounted inside the filter box obviously with the lid off. Bought this by mistake because everyone keeps calling them uni-PODS. So I bought the K&N RU-0210 (individual pods) to run with no air box. Not sure which way to go yet? Can get them both on e-bay.
UNI FTW!!!! There's no better motor protection than a UNI and a Outerwears wrapped around it . K&N is inferior to the all mighty UNI!!!!!
:shootself:
uni filters are a great filter!! i ride in the coal region witch gets real dusty!!! so dusty you cant see 10ft in front of you!! i found that for me uni filters are the only filter that keeps the shit out!! sure k&n's work good if your in front of the pack..but to anyone that thinks there are the best filter,come ride where i ride and follow 6-15 screaming banshees kicking up all the dust.. at the end of the day pull the k&n's off and take a peak inside your carbs.. you just might change your mind about K&N filters!!
If you go to the uni filter site , they list all of their universal pod filters by size . Measure the inlet ( outside diameter ) of your carb , and find it on uni's site . Just match up the part number and you are good to go.
hey im looking for the uni outerwear set up as well...im on rocky mountain does ne1 know exactly wat size pod i would need for a keihin 35mm??
2-1/4 id
6" long
I run the angle
Ive ran K&N on every car, truck, motorcycle, quad, dirtbike, we used them on sprint cars and never had a problem. I also run coal. Sorry Buckeye if you not of had luck them them but my shit is always clean. Im running the knockoff K&N's now and even those seem alright. :shrugani: .
