When i kick it over nothing at all happens. I can smell fuel. Could it be in the electrical? If so where do i start and how do i test?
ery 3 to 4 kicks? Wow....that seems a little low on the amount of spark. Do you have the TORS units still on your carbs? If so i wonder if its limiting the motor by cutting down the spark. IF you have the TORS units still (big silver boxy looking things on the tops of the carbs) then look under your fuel tank.......towards the front on the left hand side of the tank you'll see a little black electrical box. Unplug it. It is the brain box of the TORS units and will disable the TORS as soon as its disconnected.
the choke tube is in place. and the tors is eliminated. Im gonna check the engine stop switch for contact next. any other ideas?
spark every 3-4 kicks doesnt sound right, is the bike trying to spart at all? timing could be the issue...
Got it, it was a bad key switch I over road the switch and it started right up.
