jack2012
Everything posted by jack2012
  1. I'm in OH to wheres the other one your not going to buy?
  2. I want to put 10" wide tires on 5" wide rims. Anybody got any input If this is possible?
  3. I want to put 10" tires on 5" rims anybody know if this will work?
    1. SKEETER
      SKEETER
      Ofcourse it will
  4. look, they are all new the inside spring came off. so i need to change it. If your gonna get mad, just don't comment. kool?
  5. Thanks man big help
  6. Looks like you were right. tranny fluid was a half low, so i took the cover off and fond the crank oil seal was bad. i have another one. is there a way to change it without splitting the cases?
  7. Theres the you tube link you can see the build. I synced the carbs with a hose oil tool And leveled them out. Could it be a needle jet or main?
  8. No smoke when turned off.
  9. Is there a way to make your own timing key. If so please answer.
  10. The book says 24.1 but alot of people on here say 32.1 whats better and what is the performance differance?
  11. Thanks guys
  12. Got it, it was a bad key switch I over road the switch and it started right up.
  13. the choke tube is in place. and the tors is eliminated. Im gonna check the engine stop switch for contact next. any other ideas?
  14. ok im getting spark from the plugs once every 3 to 4 kicks.
  15. When i kick it over nothing at all happens. I can smell fuel. Could it be in the electrical? If so where do i start and how do i test?
