seen this the other day when i got my bike dyno'd... didnt tell them that i was taking pics though... said it had 18" of travel custom baja banshee...
I count 8 different suspension mounting points held in single shear, and suspension load members carrying a point load to frame members that are in tension. EEeek! I know they race these frames in the baja & all that, but there are some huge structural no-no's on that frame. I wouldn't ride it, even knowing its held up fine through quite a few baja races. Structural Dynamics classes in college ruined a lot of fun stuff for me. lol
i never went to college and know thats a bad idea. the rest of the atv industry thinks different though.
Foot pegs are single shear mount style. ;)
So are almost all the lonestar hill shooter and drag chassis. Or any chassis that uses heims for A-arm mounts.
On this chassis, the weight load is focused on the shocks and the outer end of the A-arms. The front to back shear load on the inner A-arms mounts is lessened by the large triangulation distance between the front A-arm mount and the rear.
I get more freaked out by the use of heims than that chassis design. You can worry about single shear heims at the mounting points all day....but you still have the heims at the ball joint location.
You want to see a wicked chassis....do a search for Lew Jr's version of that chassis design. He calls it his Trophy Truck chassis. Baddest ass bike I've ever seen. :clap:
Besides all that shit, it's ugly.
I call the Sundahl frames the I-beam abortion. It's like an older i-beam ford pickup raped an a-arm ford pickup, and had an ugly ass baby. Have you guys ever seen how these things articulate? Like shit, that's how. Camber gets all fucked up through the articulation. +/- 8 degrees I've seen. They are so unstable that you wouldn't be able to corner for shit. They're fast in straight line whoops, though. Center mounted a-arms would pull more USABLE travel than that sundahl abortion.
Can't tell the difference between chromoly teflon heims and cheapo heims, can you?
JMX12T's have a radial load rating of over 28,000lbs.
Edit: Just looked at the pictures again. I was wrong, the heims used at the frame location appear to be RSMX10T's. They have the larger shaft. In that case, the RSMX10T's have a radial load rating of over 40,000lbs. The ones on the spindles are definitely JMX heims, though. Which seems backwards, he should have used the bigger heims on the spindles, but if he exceeds 28,000lbs on those heims, that entire frame would crumble before the heims even THOUGHT about breaking.
I like it......I bet it floats like a caddy. BUT....I would take cam's Outlaw banshee in the for sale section before this one.
or that 611 would do as well.
Gary, get with it... Outlaws are stock 250r geometry... Nothing special about them. I aughta smack you!
Why change a good thing? Just make it better by makeing it fast. lol
Haha, true true. I just cringe every time I see the god awful price LSR charges for their outlaw frame, when really, it's nothing out of the ordinary. I've seen better designs built in garages... 250r's are pretty sweet though. I bet it would corner better than a sundahl, but they don't even have close to the same wheel travel.
