OhioShee77 Posted April 2, 2012 Report Posted April 2, 2012 who makes the best replacement cylinders? I have the ability to reverse engineer , improve upon (Port wise) and cast said new product. with that being said, what are the improvements you would all like to see in the replacement cylinder area? nothing is to small or to large to change. i've heard on here that some of the companys have had problems in the past with anything from machining to poor casting quality so lets hear it!!! Quote
OhioShee77 Posted April 2, 2012 Author Report Posted April 2, 2012 Re-inventing the wheel? No just wanting to have a good quality replacement cylinder with as cast performance ports! Quote
4strokekilla1987 Posted April 2, 2012 Report Posted April 2, 2012 No just wanting to have a good quality replacement cylinder with as cast performance ports! how about price that would help alot Quote
AKheathen Posted April 2, 2012 Report Posted April 2, 2012 how about lotsa meat to work with. i, personally would like to see a "grizzly bear" torqey woods cylinder, that can be re-ported for anything from woods to dune. really, i have been concidering chopping a serval down for lower timings. honestly, though. i do not condone reverse-engineering good cylinders, rather, go through the same process and start more from experieince of knowing the cylinders. one big thing i want to see is electric pv's. i can run those from the dyna. Quote
Coupelx Posted April 3, 2012 Report Posted April 3, 2012 This will not end well and honestly if you have to ask this question, you have no business reverse engineering anything. Quote
BigRed350x Posted April 3, 2012 Report Posted April 3, 2012 Why ask the question? Look around and you will see who the big-name cylinders are out there. CP Industries, Superior Sleeve, Twister. I believe RDZ makes a billet block as well as vitos. Quote
