Took bike down to frame, the front brakes worked fine... Put together, tryed to bleed brakes and it's not building up pressure? No leaks at "t" or any connections, am I missing something here? You pump the MC, hold...crack valve like any other system correct? Also thought maybe the piston was bad on MC, installed one off dif bike, same thing
Thanks what I figured I'd end up using after about 15min of irritation. Ran out of daylight gettin other stuff ready I'll purchase one tomorrow though :)
mighty-vac !!
Gravity Bleed. I do cars this way too since i rarely have someone to help me.
put teflon tape on the the threads of the bleeders and then a couple inches of clear hose. put a pan under each hose and then crack the bleeders open a turn or so. Grab a beer and keep the master cylinder full. some times if its really dry pumping the MC quickly a couple times gets it started.
