YFZ 450 Shocks
DirtDiggler69
I see the pinned how to BUT the pictures aren't showing up .
I got my shocks today and the upper mount looks like it needs to be ground down a little bit for the bolt to line up.
I'm using +2 a arms so the lower mount isn't an issue . Anyone else need to grind some of the bottom Of the upper mount?
I don't have those shocks but i have heard many times that you must grind a little bit off in under for these to work. Enjoy your new shocks.
I got the front suspension installed today , I have new ASR tie rod ends on the way so next week the shee will be back on her feet .
The YFZ shocks are a tight fit but everything slid together nice .
Did you happen to notice that your spring is touching your upper a-arm?
Hard to see in the pIcture but there is very minimal clearance ,
It has about a 1/4" of space .The other side is the same .
  • 2 weeks later...
I got the front end all together and the YFZ 450 shocks clear everything , my a arms I am sure are ASR +2+1 standard travel . The Shocks were a tight fit and at full extension the spring does touch the a arm where the heim is threaded into , but no binding at all . I got the shee back on her feet and ran the front suspension up and down and found no problems . I can't wait to carve some dunes and trails !
  • 1 year later...
